PSU Help
acertey
was looking around for a PSU as well, was considering a 750W, as will likely do some slight overclocking. Does SuperFlower have a 750W valued PSU?
royfrosty
Have and i have a new one never use. If you want can pm me.
Platinum 750w
acertey
What config for 750W? W/ CrossfireX or SLI?
Simple config, AMD 8320 & Asus Evo, with a Gigabyte R9, 280X, the rest i think pretty normal stuff bah. Was a bit worried that a HX600 not enough juice to overclock. Only doing slight overclock, confirm not a super enthaustic... :s13:
royfrosty
Then HX600 is enough.
