psu problem?
unrealx262
hey guys i posted this thread a week back http://forums.hardwarezone.com.sg/hardware-clinic-2/autoshutdown-problems-5240823-3.html
seems to problem can back again, i didnt manage to get a replacement the other time and continued using.
ok this is the "faulty?" seasonic 520 unit
and i got an old supposingly faulty andyson 500W to check
First my kb and mouse led died out after 5 min turning on the com. then i went to restart the com and reseat the usb. then subsequently cannot power on and the above symptoms occurred. now i using the backup psu and the mouse + kb still wont work, i had to use other ports (usb3) for it to work as below
gld998
suspect your board kao kao liao based on your description. Backup PSU not work also means not your PSU taichi already
gld998
Have u try reapplying thermal paste? USB not working means not enuf power or spoilt. Do u overclock?
unrealx262
not yet, but even so how does it explain that the psu for seasonic wont bootup as compared to andyson one . no oc
gld998
so your problem is not psu... other component dying soon. How old is your machine? run 24x7?
unrealx262
oh why not psu, since swopping the psu made the difference partially? whole rig since oct 2014. no not 24x7.
gld998
since u are convince that the psu got tai chi then go corbell claim? let them check? :s22:
hlots123
veryyy long shot, but can u try off psu rocker switch, remove power plug cord from psu. then press & hold power on button on the casing for 10-15sec.
then put everything back, power on goto bios reset to defaults. after reboot see if usb2 ports come back to life or not?
p/s, ur casing rear fan always no spin, is disconnected?
unrealx262
Will try later. But all is good when i use my andyson and i could use for 3 hrs last not.
Sent from Samsung SM-N9005 using GAGT
unrealx262
i put back to the seasonic psu, can run lol wtf (means whole system can boot up and posting this post using it)
i did your method but the usb still gg, now using usb 3.0 ports
hlots123
u mean simply change back seasonic psu, can boot pc already when previously cannot boot?
unrealx262
it is spinning as usual. yup i change back can boot alr, last night cannot lol :s22: its like on-off issue. nvm i will drop by nigel shop later
xp20046
I might have a similar problem.. PSU should be working as CPU fan and GPU fan is spinning but BIOS cant boot up..
Allanlee82
most properly is your mobo got problem, came across such issue before on my friends pc
on cold start, able to boot into window but if try a reboot, cant even startup or sometimes will stuck at windows loading screen
usb ports not working also could be mobo issue, my board had to rma also because of this, one of the usb is always not working properly even after i reinstall the usb driver
