KWSW
- Jan 1, 2000
In my attempt to change the fans in my system to something better, I realised that my mobo ROG C6H fan header supports 1A current each.
The fan I am looking at, the Noctua IPPC 3000 requires 0.55A so if I use a splitter for 2 than the total would be 1.1A. Thus I would need to get a PWM fan controller.
Any good pwm fan controllers to recommend? Dont need any UI or Software as I will just plug it to my mobo pwm header and control via my mobo bios.
Thanks in advance!
Sent from Samsung SM-G955F using GAGT
Thanks in advance!
