gaoxing84
- Feb 12, 2004
Hi guys, I got a question using pwm 4 pin fan splitter cable.
I am currently using 2-way 4pin Pwm fan splitter connected to one of the cpu 4 pin port.
The splitter splits into 2 fans on my 120mm rad.
Does the pwm signal is being sent to both pwm fans or only 1 single pwm fan?
Cause I can see only one fan is spinning at a higher rpm while the other is slower when on load.
