Hi all,
Currently I am using only 2 x 8gb RAM dual channel kit on my X99 platform.
Is it advisable if I add on 2 x 8gb RAM dual channel kit to run quad channel instead of getting a 4 x 8gb RAM quad channel kit? (same manufacturer and spec)
From my limited knowledge, quad channel kits are tested to run compatible as a kit.
Any risk if I use 2 packages of 2 x 8gb dual channel kits (for quad channel) since the 2 packages havent been tested together?
