kuti-kuti
- Sep 28, 2018
I understand that some countries currencies are not listed inside the app conversion tab, but we can still use the physical card in the country [eg malaysia] as long as there is sufficient sgd inside the wallet and youtrip will just convert the purchased amount according to the present rate.
my question is, with the above flexibility, we might as well not convert to any foreign currencies at all to be put inside the wallet becoz any un-finished foreign currencies left over after your trip, if u convert them back to sgd will lose 1x conversion rate charges mah.
so just keep sgd inside, don't convert. use it to pay on the spot conversion when overseas better right?
