Question: x570 Aorus Pro Wifi Debug LED
Iceman127
Looking for Pros input. :D
Question on debug led for x570 Aorus Pro Wifi.
Any user of x570 Aorus Pro Wifi when booting up the computer, notice the debug led for the motherboard will blink from cpu,ram, vga for 1 or 2 sec each before booting to windows.
This happens each time PC boot up from power button or when computer reset.
No issues found on booting to windows of usage.
Is it a normal cycle of debug LED or a signal the components have small issues but still able to boot to windows? :s13:
Thanks in advance! :s12:
NightRaven49
msi boards have the same behaviour. should just be part of normal post sequence, so nothing to worry about.
Clearnfc
Duh, you meant you never read the manual about what it does?? Its just to show initialising sequence. If you see the LED stop at RAM, means there is likely a RAM problem.
CursedHamster
Debug LEDs cycling through the 4 option is part of the POST process. Only need to worry if a LED is staying on and you cannot boot into windows. If can boot into windows then can ignore already. I witnessed some quite rare cases of Debug LED staying on but PC no problems so not sure if is bug or something else. I would think the former.
Outramkia
The led will cycle through. If stuck means gg liao
Iceman127
Thanks bros for the reply and advice. :D
Was wondering if it’s standard for the LED to cycle through when booting.
I assumed that nth will light up unless got problem. Haha whoops.
Iceman127
Haha got read but it just state light up stands for what issue, didn’t mention that all will light up in sequence during booting and will stuck with led light on to show issue.
Was assuming that if nth wrong, they won’t light up at all during boot. :s13:
Anyway thanks to all the pros here for clarifying and answering. :)
Iceman127
Thanks again to all the bros/pros reply on my question.
Got my answer.
Mod can close thread Le.
Thanks!
