Questions about cases (air cooling)
ryuxdragonx
I've been racking my brains out to figure out the best case for me.
I would like a case that has a window because I want to install blue LED strips for lighting.
I would also like a normal size mid or full tower (not as huge as a 800D), nor something that is wider like the Fractal Refine R4
This build is meant to be a mid to high end gaming machine, with dual boot into hackintosh as a partial workstation for graphic design until I get through army, maybe even last me though uni days before I get a MacBook or Mac Pro.
I know I have the choice of AIO liquid cooling with something like the Corsair 100i or the 80i, though I'm trying to avoid these options. I might if I have to but I like having a huge heatsink because I think it looks badass.
Here are my current choices so far:
CM 690 III Windowed
Corsair 750D
Corsair 650D
CM 690 III:
I really like the CM 690 III but I hate the fact that it does not come with rubber grommets and it has very little functionality in terms of cable management. It also seems to be made of much cheaper material compared to the other corsair cases.
Corsair 750D:
I think this case is great, except that the front panel doesn't seem very optimised for air cooling. It seems that it would be difficult for cool air to come in from the inside, which might cause overheating under heavy load. Can anyone who owns this case give me some insight into air cooling with this case?
Corsair 650D:
I love this mid tower, except that this is very expensive. I wouldn't mind paying about $230 to $240 for this case, but mynextcom currently retails this for $282. Can someone shed some light on the Tradepac price for this after discount?
Here is my current build plans (with intention to OC)
Core i5 4670K
Gigabyte Z87-D3HP
CoolerMaster Hyper 212
Corsair RM 650 PSU (80+ gold)
MSI R9 280x
Kingston SSDNow 120GB x 2
WD Blue 1TB x 2
2 x 8GB Ram (I'll get whatever is cheaper at the time of building this rig)
NZXT Sleeved Blue LED
With regards to my choice of PSU, yes I know that I might get better value with the Superflower HX 600, but I like the look of the Corsair RM series, and also the cables that comes with this PSU are flat, making my cable management much neater. I'm a neat freak when it comes to these things, so I don't mind spending that extra 30-40 more for that feature. I've done extensive research so I think my choice of parts are pretty decent.
Check out an unboxing of the Corsair RM PSU to understand what I mean: Corsair RM Series Power Supply Unboxing & Overview - YouTube
Any suggestions would be greatly appreciated! :D
royfrosty
Haha you all read my mind.
Ts. If you are a neat freak, just go for the corsair carbide 540 air. With its unique dual chamber design you could put in all the necessary components that requires cooling at the primary chamber. Psu ssd dvd and all other wires can be hidden at the secondary chamber.
Best of all it does not need any wire management as no air is needed to pass thru that chamber.
:frosty:
xtwis7
+1 for royfrosty. Once go with corsair 540, never look back.
royfrosty
The lowest price I got is $155. Best buy or tradepac.
BTW the stock front fan included is an AF140 quiet edition series with white led. Is quite quiet at 1200rpm max.
Ark Law
in sg i think x3 scythe @ $20 would be better
Scythe GT is loud. Even when undervolted, if the exhaust side of the fan is attached to a grille (be it a rad or casing), there is audible turbulence even though the actual motor is quiet. I have no such issues with my current NF-F12. At $28, it's expensive but you get Noctua's support for 6 years
schlep
Sorry to hijack but where in Sim Lin can I get the Scythe GT the cheapest?
ryuxdragonx
Hahah 540 too wide lah. I know royfrosty bro suggested that to me before.
I know 540 good for air cooling but cannot lah. Just not my type of case man heh. 750d is big but it's the tall and slim compared to 540, if u get what I mean.
ryuxdragonx
I think I'm gonna go with the 650D leh. Anyone know trade pac price? I like that it has a fan controller I can save money on that, and it's a beautiful case.
