Hey guys!
Just wanna do a quick check if my Ryzen R3 2200G idle temps are okay. Here is my current readings from HWMonitor:
Reason why I'm checking is because my idle temps has been around 40+deg for Mainboard and below 40deg for CPU. However, recently I noticed that my idle temps have all increased by around 5 deg even though my usage remains the same. As you can see, I did not open a lot of programs/chrome tabs etc.
To share my specs if it's related, I did not change any parameters even after reformatting, and my iGPU allocation is 2GB, with positive = negative fan pressure (2 inflow 1 outflow). My ram speed is @ 2666MHz.
Hope I can receive some feedbacks or sharing from other bros out there too! Thank you all!
