R9 390X will Be using AIO Liquid Cooler....
shadow84
NOise will come from the fan that is being used and maybe the pump as well..
Ark Law
Being AMD, pretty sure that the rad fan will be an A380
Alternative X
Wondered if the manufacturing partners will come out with an air-cooled version anyway like the Powercolor R9 290X Devil 13?
Alternative X
Yes, no noise. Your point? You trying to fuk aroung with me?
Not happy trying to pick a fight? How about you go fuk your mother?
Son of a *****. fuking ****......
Ermmmmm.......... AIO cooler also got pump noise and fan noise, cannot exactly call it completely silent unless the R9 390X uses a passive cooling heatsink with completely no fans.
Ark Law
The cooler is manufactured by asetek......
So? My Antec 920 is made by Asetek, the stock fans are like Eurofighter.
And AMD have never been known to go with a quiet profile in recent history
Op_Valkyrie
bro.. just one comment nia u so hot for what.... waiting to see more reviews from u... don stop on that :o
Alternative X
If the stock fans are as noisy as the Eurofighter, what did you replace the stock fans with? Gentle Typhoons? Corsair SP120?
shadow84
I think you posted in wrong forum? This aint EDMW...
royfrosty
Custom wc ftw. With monstrous rads you can even run it on passive with no fans. Or perhaps run everything on low rpms
Felfirez
Don't worry, should still be cheaper than GTX980 as usual :s13:
:s13: but I quite excited about maxwell especially after seeing the 750 and the leaked mobile versions benchmarks.
And I tried playing on a gsync monitor. It's so buttery smooth... For once since the 200 series, I want to get nvidia.
