mib500
- Sep 16, 2010
But earlier got post mentioned 980Ti lose out to fury X in direct 12?
I never follow up the articles, izzit true?
dont think so... we just wait...
The ashes of singularity benchmark uh?
I think too early to say. anyway the fiji core and the GM200 never fully roll out all of DX12 Features
Maybe next gen? Arctic Island/Pascal.Any ideas roughly how long the wait will be?
Fury X AIO can install meh? The HSF seemed to overlap into that space.You can go for 980ti reference card. But at this time there is only 1 or 2 ref card left in sls. And that is most likely gone.
You cant go for non ref though. As non ref, high chance you cant go for broad and wider cards.
Most of the non ref you will highly fail to fit.
According to the specs of ncase m1, it can only fit this.
GPU
Rear exhaust cards recommended, especially for cards with TDP greater than 150W. Look up your card's TDP (external link).
Max length: 12.5" (317mm) in slots 1 & 2; 11" (279mm) in slot 3
Max height (or width):
For cards up to 12.5" (317mm) or cards in the third slot: 4.4" (111mm)
For cards up to 11.5" (292mm) in the first or second slot: 5.5" (140mm) (4.7"/120mm at the PCIe power connectors)
The first requirement already will fail. As it will be too hot to handle a high tdp gpu. Nevertheless heat will be trapped inside.
So TS, i suggest there is a few ways to go with it.
1. Gtx 980ti ref card
2. Fury X and sacrifice a 3.5inch hdd slot
3. Fury Nano with no sacrifice needed but you must know how to push hot air out. As the nano is definitely higher than 150w.
This heatsink only can mount this way, the other 3 ways will either block ram, gpu slot or cannot close the top panel.
If the clearance for heatsink is enough to slot in fury X radiator, I had to shift my heatsink fan more to the left. (Fan will not be at the center of heatsink even if I change to 120mm fan & mount on Ncase panel)
He will reserve one meh...
And lolol @ 980Ti performing marginally better than nano.
Sent from JARVIS using GAGT
Precisely!I thought the 980ti already exceeded r9 fury x performance? Nano is underpowered compared to the x. So i don't think it's marginally better than nano.
But I think ts inclined to purchase red camp card mmm...Yes, he will reserve if u intend to buy and u ask him to. That was how I got the last piece of 980Ti Lightning (in the first shipment batch) from him.
Jonsbo C2 not too shabby for a small case. Well built as well.Such problem is prevalent on all small chassis, just like my Jonsbo C2. If you can DIY well then it is not small. People go small for a variety of reasons...
In a closed space, I think you'll need to rephrase your sentence for fury x.I thought the 980ti already exceeded r9 fury x performance? Nano is underpowered compared to the x. So i don't think it's marginally better than nano.
Shut up gatt. Nano is not overpriced.Just patiently wait for 980 Ti ref, if need to, ask Yilong reserved for you. At least the 980 Ti does not have 2 extra tubing running out with a rad and it perform marginally more powerful than the overpriced nano.
Since you are going for such small build, its probably one of the few limited choice left.
so right now which gpu you gonna buy?![]()
Precisely!
I'm ok with both camp although I never change much GPU.
FX5200 -> R4870 -> HD7850 Currently
Still considering.... currently using onboard.
need to check the card measurement before I can decide
Precisely!
980ti ref is a sure fit
Hi, Ref card is no brand under Nvdia or those with branding eg. Asus, Msi etc
Ref meaning the cards with the reference cooler. Nvidia doesn't sell GPUs directly anymore and hasn't been for years.
Will there be any indication on the board, how to I identify it?
