Razer blade 2014 issue :( Help!
chaienz
Hi guys!
I got my Razer blade 14' model 2014 and now the keyboard and touchpad are not working anymore but the touchscreen, CPU, GPU everything still work well. I have sent my laptop to razer support but the said i need to pay for the motherboard and cost is very high so i refused. Can someone please tell me where can i repair it ?
Thanks!
yusoffb01
Hi guys!
Thanks!
laptop motherboard can only get from same model. not like PC desktop can mix and match. I think its ridiculous keyboard and touchpad spoil no need change motherboard.
Try reinstalling WINDOWS 8
or buy a new keyboard like this one
http://www.lazada.sg/logitech-k400r-wireless-touch-keyboard-white-355898.html
jace88
I'm surprised they can't change just one component but it's hard to say without knowing why it's not working - e.g. is it hardware failure? I've swapped laptop keyboards and trackpads numerous times but then Lenovo do make their laptops easy to swap these pieces...
Previous suggestion of buying another keyboard is good but it won't work so well if you need something portable for gaming.
chaienz
i also thought they just need to change a part of the laptop but they not and the cost higher than thousand dollar :(. now i have to use external keyboard and mouse
chaienz
Try reinstalling
yep. i had try many ways but still now work (reboot, driver). i already bought external keyboard :( but it not comfortable for me when i want bring laptop outside :(. Anyway tkx u
Digital Hospital
Featured Distributor for Notebook Clinic
Try reinstalling
You can try to get the motherboard repaired.... :)
a562140
thats always the risk with buying with a company that doesn't specialize in PC - they can't hold stocks, and if they do - it will cost an arm and a leg without economies of scale.
