razer mako problem, pls help!!
noobkia
dear all,
was using the razer mako speakers for the last 9 years. today, suddenly there was a loud tiak sound and a small burning smell and the speakers went dead. light on control panel disappeared and cant restart it.
any repair shops to recommend and any diagnosis on whether it can be repaired?
looking forward to the kind advice from expers here. kam sia.
commach
Tiak loud or **** loud doesn't matter, no different.
The primary circuit fried, usually the capacitor right after the rectifier busted with sound and burning smell.
idjekyll
wah bro 9 years leh. consider yourself lucky to be able to stretch a Razer product that long write a small eulogy and move on. and 1 minute of silence (pun intended).
wwenze
Even Razer don't care about this product, discontinued so fast after release.
