RE: Need help with some question
Hi All,
I got some spare 4-pin y-cable (4pin split to 4pin & 3pin) from my Noctua fan, and need advise on the following.
1. Can I use the Y cable for my motherboard CPU fan, will it detect my temp & auto adjust the fan speed?
2. Instead of buying a 1 : 3 split fan cable, I use 2 x Y cable for my chassis fan.
3. My mouse Logitech G700s still light up when using cable (Charging) when my pc is off, is this safe?
4. Where to get cheap and good Dremel to cut aluminum? My side panel had arrive & I intend to modified it.
TIA
Hi All,
TIA
