Realme GT2 Pro Series
thewiseone
Hi all, not sure if it's only me. When I try to share a photo to WhatsApp, there is a long list of irrelevant app options and even after selecting WhatsApp multiple times, the WhatsApp option still doesn't move in front. I recall my previous phone will learn from user selection experience. Thanks
Not sure if this works for realme os but for coloros, long pressing whatsapp icon when sharing and a menu pops up for u to pin whatsapp to the front of the list.
villan
hi all, i just received the carbon fibre case but not using it as i sold my phone...bought for 35. now letting go at 30. pls pm me if keen.
Thanks.
rainbow99
Can I also ask if there is any workaround to remove the fingerprint unlock animation. All the options too bright and distracting. Samsung phone was able to remove the animation. Thanks
Milo-Dino
If I remember, can change the fingerprint animation. Not sure if can remove totally
waterballoon
Settings > Customisation > Fingerprint
Think got option without any. You try lol else pick the least bright.
Anyway, not just the animation bah that area has to light up cos it's optical fingerprint scanner so there must be light to çapture a pic of your thumbprint to match with what was recorded...
eeeman
Hi guys, I also booked the set now with Shopee flash sale. Manage to get it at 769. Have been Samsung supporter for years and 1st time switch to Realme. Can propose best way to migrate? This is my headache coz may need to reset lot of apps…smart switch? Or any others?
rainbow99
Not sure if it's me only or due to the recent A16 update, I can't seem to share photos with WhatsApp and some apps from gallery or directly from screenshot anymore. I have to go to WhatsApp to attach the photo. May I check if the rest of you have the same bug? Thanks
rainbow99
I used the Google restore function for the apps installation, and the smart switch for non-app data like SMS. Faster than I thought
rainbow99
I also no longer see the ultra fast charging indication on the lockscreen.
jericho75
Anyone can help me on the charging cable? Anyone knows which charging cable which is usb-c to usb connector to the original charger that will work for fast charging? I need a 2 meter length. ordered one came and the fast charge dun really works. if got lazada link will be better. thanks
Milo-Dino
I think you need to find cable that allows 6.5A current in order to fast charge
Since u need 2m long.. Looks like only those oneplus brand ones. Like $14-27 range
jericho75
those u green one leh? some says fast charging works some say dun work. :(
oneplus got cables also?
jericho75
Ugreen ones don't hit 6.5a.
Fast charging is not the same as realme dart charging... Different ampere and tech slightly diff.
Oh. That fast charging cable works on my mi pad 5. But plug into realme gt 2 pro. Then the % dun move one. Dart charging needs special cable?
