xonix
- Mar 24, 2001
Wahh chio. Did u ship it direct from JD or used a forwarder(ezbuy)?
Sent from LG G7 ThinQ using GAGT
Mwas thinkjbg if x3 pro for POGO...or for my son but no sd card.ore however, more keen in your gundam![]()
just arrived, nice box
Chio! Show more pics pls!
Does Google pay works for the China set ?
direct from jd, no hurry, took abt 18 days to reach me![]()
jd ships to sg?![]()
So nice....now fighting between x2pro or reno ace(gundam edt)Just received the Realme X2 Pro Global EU version from Aliexpress. I think there is only one seller there that sells this Global
To tell the difference between Global and China version, first check the packaging box, there should be "Snapdragon 855+ 64MP Quad Camera" under "Realme X2 Pro" on the front of the box. The China version will not have this text.
The back of the box should also say only for sale in EU.
The phone came installed with all Google apps and Facebook, YTMusic, etc. I checked with DRMinfo app and it has Widevine L1 support.
Check the firmware and it should say RMX1931EX. China rom is RMX1931.
There is a Black Friday deal at Aliexpress so now is a good time to get this phone.![]()
Can provide link?...so many not sure which
Just received the Realme X2 Pro Global EU version from Aliexpress. I think there is only one seller there that sells this Global version.
[ IMG]https://i.imgur.com/onM8lwx.jpg[/IMG]
[ IMG]https://i.imgur.com/F83DQk7.jpg[/IMG]
[ IMG]https://i.imgur.com/znxNSSh.jpg[/IMG]
https://www.aliexpress.com/item/4000262749144.html
Depends if you can live with China rom of the Reno Ace Gundam, or you really like the design of the back of the phone.
Bro,is this link seller same as the one u provide?
SG$ 587.17 28%OFF | realme X2 Pro 8GB 128GB NFC 6.5" Moblie Phone Snapdragon 855 Plus 64MP Quad Camera Cellphone OPPO VOOC 50W Fast Charger
https://s.click.aliexpress.com/e/DudkktvI
Your link is from the same store I ordered.
