Recommand a CPU cooler ><
hotcaptain
sorry hijack the thread
can
Coolermaster GEMIN II M4 fit into jonsbo u2
Any other recommendations?
pkjames
Hi guys, im back haha~ its been awhile since i last post. This time round, i will share some pic of my recent noob build so pls dont flame me :x
Hoot slowly arrive....lastly the ram :D
Comparing with my 6yo ATX PC... love the difference :s22:
pkjames
Continue...
Bobian, have to turn liao. But in order to do that...i need to remove something :x
Yesh, i remove the sound card casing. Now everything fits perfectly. :s13:
pkjames
Continue...
Gonna love the setup for HDD & SSD, at the other side of the casing :D
Wiring done :D abit messy tho
Just another comparison :s13:
pkjames
Continue...
Incase u guys are wondering, does the cpu cooler really fit into the casing?
n lastly...it boots up normally on the first try :s12:
pkjames
Some lesson i learn from this ITX build.
-gonna be extra careful when buying parts.
-gonna be extra careful too which part to install first :D
-Always prepare a USB thumbdrive with Window OS install :X (ok, for this part, i just use back my old HDD&SSD without formatting. It works but the window will go crazy. XD)
Currenlty using an budget 750ti gpu. wish to change to something better in the near future but the problem is....can a 1080 fits in? :eek:
ZrE0_Cha0s
with that cooler of yours and the psu down there i still think its a risky move to squeeze it in... :o
Kikstyo
Make sure the GPU thickness is 42mm or lesser as the PSU/GPU not much clearance. How are your gpu load temps now?
pkjames
This part looks like as though an octopus just rape your pc inside :s13:
but why dun u keep those power cables u aint gonna use??? :s22:
hahaha the fact is, im using those cable (less the GPU coz 750ti can power up from the mobo alone.)!
What u see there is what im require to use :D
hlots123
did u mount d15s wrong way? the cooler is asymmetrical, and is usually mounted leaning away from gpu slot (with fan on rear tower by default).
urs look like leaning towards gpu slot, and fan on front tower, blowing wrong direction...
pkjames
according to the instruction, it can be mount on either way. but in real world experience, it really depends on your mobo. for my case, the Asus impact has some space restriction for my cooler which i am force to mount it leaning towards the gpu. i have been checking the temp every now and then, so far so good :s13:
hlots123
oic, the impact got a daughter board at top edge... wah with this board u shud hav considered a different cpu cooler but hope it works out well in the end!
btw u can consider relocate the fan to the rear tower...?
pkjames
haha that time never think too much. i even email do respective manufacturer asking about the compatibility and every1 reply 'yeah yeah yeah, it will fit fine' :\
u mean the middle fan on the Noctua?
hlots123
yah tat fan, can it be clipped to the rear tower?
