Recommend 2.4ghz/Bluetooth Wireless Mouse
calvinlim18
Sick of Razer getting sticky after awhile. Or does the new Razer mouse now come without the rubber coating?
Budget <$100
wwenze
Just bought a M$ one for $20 from Lazada... BT
nod32fan
Logitech M590 is a silent mouse. Supports 2 devices. Cheaper than retail at some sim lim stores.
Habrosus
I'm using the Logitech M570 2.4GHz Wireless Optical Trackball Ergonomic Gaming Mouse, though I'm not gaming.
Targeting the Logitech MX ERGO Wireless Trackball Mouse next.
Morugana
just buy the cheapest logitech bt/wireless mouse $20
use sticky or spoil just throw
Rogue
Budget <$100
Avoid rubberized product... My logitech hero mouse wheel(full rubber, not plastic) turn to mush too after only 9 months of use. Now it's really hard to turn it and will toggle my DPI shift button... It might be the weather(hot), or they skimp on the rubber stabilizers or other chemical compounds you accidentally transferred (wash/dry your hands often. E.g Medicated oil or just simply oily hands...).
Hard to avoid rubber nowadays though, all of them have some form of coating... Either you buy cheap and throw often, or clean your mouse once in a while(isopropyl alcohol works) in additional to personal hygiene.
