Recommend a CPU cooler better than Hyper TX3 Evo pls
cenedra
Im currently using a CM Hyper TX3 Evo. Just wondering if there's any other better CPU cooler than this and at the same time dont have a backplate?
Reason being I wanna avoid the trouble of taking out my motherboard and put in a backplate...
Thanks~
shadow84
Almost all will have backplate de... The only 1 i can think of is intel stock cooler. And maybe some of Deepcool heatsinks.. Presuming that u r using 115x.
DEEPCOOL Intel LGA 1150/1155/1156
But, frankly, the performance difference is negligible. Those that are using intel locking mechanism are usually the low end.
All the better ones WILL have backplate for support de.
