nicky9499
- Oct 17, 2008
Hi all,
I have a CM Seidon, my first foray into anything WC. Supplied fan does a great job and the unit itself is excellent. However in order to perform said job the fan goes up to ~2400RPM which is pretty loud.
I'm thinking more air pushed = better performance? Can someone recommend me a good fan with high static pressure/CFM what will fit the bill for a replacement?
Thank you.
Thank you.
