Recommend a PC controller pad
xtwis7
Does the XBOX one controller comes with the USB dongle?
kewellz
Been using logitech rumblepad, wired one last time bought around $50+/- at challenger, quite good, last for few years already but now the wire like something wrong always disconnect, but overall it work quite well for me. Been like many years though.
Use it to play GTA4, GTA5, FIFA, PES all no driver issues, dont have to download anything, plug and play.
Gametaku
Go for DS4..wont go wrong. Most sg console gamers will buy a ps4 over xbox one. U can use it as ur spare ps4 controller if ur thinking to get a ps4 in future.
koroshiya8
There is a version which is charge and play pack.. that one got cable..
the normal version dont have and you do not need because xbox one controller uses the standard micro USB cable.. so literally any USB cable u use for your android phone etc is 100% fine.. the only issue is probably the length.
This is where DS4 comes in a prove useful cos it can connect via BT while XBOne for PC can only connect via cable for now.
xtwis7
Huh, XBone controller can only connect via cable? So the wireless only works with XBOX one console but not PC? But PS4 controller will need a bluetooth dongle on your PC if you have no built-in bluetooth right?
koroshiya8
Yes XBox One controller can only connect to PC via Cable. But early next year they will introduce the wireless dongle similar to current xbox360 wireless controller that works with PC.
Yes PS4 works via bluetooth as well as cable. So yes you need to get a bluetooth adapter for your PC if you dont already have one.. but BT dongle not ex is ok right ? i bought a cheapo one from dealextreme many years ago and it works ok.. like $3 only.
muddle
The inputmapper software for ps4 can work in both wired and Bluetooth. Stopped using cuz seems to have problem in win10.
koroshiya8
I'm currently using DS4windows mapping for Win10 via BT and so far no issue... i use it 80% for emulator for MAME :D quite a hassle to do mapping but it's totally worth it :s13:.
Now 2016 liao.
Got the sibei satki Xbox Elite Controller.
http://www.xbox.com/en-SG/xbox-one/accessories/controllers/elite-wireless-controller
SGD$195 Only.
I recommend getting the XboxOne Wired Controller.
http://www.microsoftstore.com/store...oller-+-Cable-for-Windows/productID.307138900
SGD$80.
Xethos
I have both F710 and xbox360 controller for PC.
F710 's trigger button is not that good and spoil easily(I have replaced one and the replacement also spoil in the end). D-pad is good. Advantage is that this has both x-input and the directinput thing.
xbox 360 trigger buttons, and their left/right sticks are better, and overall more comfortable than F710 but the dpad is bad, not accurate.
wwenze
The ultimate question...
Which one can be used to play Touhou
HWZ1973
So had anyone tried with PS4 or Xbox 1 wireless Controllers?
Which Bluetooth dongle and any software requirements to work with laptop with windows 7 to play PC games?
yusoffb01
Thanks! Think I will buy a PS3 controller to try.
If u dont need wireless i recommend getting this
http://m.ebay.com.sg/itm/Slim-Xbox-360-Wired-USB-Game-Pad-Joypad-Controller-for-Windows-PC-BEST-SEELING-/291569632493?nav=SEARCH
I have been using 3 years. No need additional software because its recognized as 360 controller
Works on xbox too
