Thanks. But anyone with personal recommendation?
i wont recommend anything else than a sandisk ultra or extreme.
32gb depends on you.
what do you shoot in ? RAW ? JPEG only ? RAW+JPEG? I shoot both raw + jpeg on d7000 and an 8gb is sufficient for 200+ shots. One thing i would say, always leave some memory left in your cards ie, your 8gb can shoot 250pics, stop at 230 and change card. never know what will happen lol....
So what do you think will happen if you hit the limit of the flash? Explode? Leak acid? And why?
not like that. just to be safe, cause you never know how memory errors.
ive maxed out a memory card before. it tkaes a while to transfer and errors happen. from there, ive stuck to the rule of not maximizing memory cards fully.. when i asked around, there are others who stuck to this rule too.
