Recommend me a Case for liquid cooling
shadow84
+1 @ Ark Law
Why wouldn't mynextcom search SLS for your casing?
Clearly you have no inclination how the shops in SLS work.
:s12:
I know how sls works, though cant b said for every shop. Not all shops would help to find.
Last time wen my arc midi r2 was OOS, i called up every known shop and ask about it. Even went down to ask every shop, including MNC. All said OOS, but nvr offer to search whole of sls to help me find stock.
But, all in all, its a good sign some shops would go the extra mile.
Ark Law
:s22::s22:
Just ask the main ones can already. If they don't have, then confirm pruss chop all other shop don't have already
Gondon72
Why not increase budget and get a 900D?
It can do double 480mm for your dual 290 plus CPU.
Cheers all. Thanks for helping and suggesting. Back to topic :)
Set my own budget to be < $300. Hope some other casing can be found in this range :)
Ark Law
Make thing simple for you, you see the price list you looking at? Go look only at Corsair section. Then short list those $150 - $300 price range.
Then go Corsair website find the specs which suit your need :D:D
royfrosty
Actually quite hard leh. Around that price range it only seems like the 750D is one of the best out there.
Unless hmmmm..... You wanna buy the HAF Stacker lol. Monster
Ark Law
Buy a fridge better. No need to even spend on setting up/maintaining liquid cooling config
Gondon72
Looks Big! :s13:
Anyway, if really cant find 750D..the next level will be 800D/900D?
hahaha..that is powerful
royfrosty
Looks Big! :s13:
Erm no it doesnt really go by bigger number means better.
900D will be the next upgrade. This is a larger chassis.
tarui04
i looked at a big chest freezer once. it couldnt handle the heat output of my pc...
fridge kind is good for small systems with low heat output nia
Ark Law
:eek:
Dont know will condense and short or not lol!
Maybe need blast chiller instead of normal fridge. Custom drill PCI slots against the side and mount reference 290s. Intake 1 deg "ambient" air, output the steam all outside the chiller :s13:
Gondon72
Im waiting for this too, dunno when coming to sg
Their global product manager post in forum said
"They will be available in late February or early March depending on your region"
hopefully it comes soon then
