Recommend me parts for a rig.
Facisttk
Hello, could i get recommendation for Gpu, Ram, Cpu+mobo and monitor.
Budget around 1k.
Thanks!
Facisttk
Sorry for bumping but getting the parts next week.
Would love some help.
Thanks!
DawnsTear
[Mobo&Proc] MSI H81M-E35 V2 /w i3-4160 - $249.00
[GPU] Zotac GTX 950 Twin Fan 2048MB - $239.00** (Lazada)
[RAM] Kingston DDR3 1600Mhz CL11 (8GB*1) - $55.25** (Lazada)
[HDD] WD Blue 1TB/64MB - $77.00
[ODD] Samsung 24x DvD+-RW - $25.00
[PSU] FSP Hexa 550W 80+ - $58.65** (Lazada)
[Case] Coolermaster N200 - $61.00
[OS] Windows 7 Professional 64bit OEM - $28.00 (Reddit)
[Monitor] Dell 23" S2316H - $209.00
Total :- $1,001.90
Buy from PC Themes unless stated otherwise
** Buy from Lazada SG App
MasterCard Monday (15% off capped @ $30)
POSB/DBS Appy Friday (15% off capped @ $25)
CitiBank Wild Weekend (15% off capped @ $30)
MoneyFace =p
Budget around 1k.
Thanks!
CPU+MB: Intel Core i3-4160 + ASRock H81M-HDS R2.0 @ $322
RAM: Kingston ValueRAM DDR3-1600 CL11 8GB @ $67
GPU: Palit GTX 750 Ti 2GB StormX Dual @ $160* (Lazada Singapore)
DSP: Dell UltraSharp U2414H 23.8" 1080p 60Hz W-LED [AH-IPS] @ $339
Total: $888 :flash::flash::flash:
Buy others from PC Themes, #04-15. Haggle for discounts!
*Price after Lazada App DBS/POSB Appy Friday / CITIBank Wild Weekend 15% off max $25 discount
MoneyFace =p
Total :- $1,001.90
Bro only those parts mentioned above....
Facisttk
Thanks!!! :s12::s12:
hachi
Anyone can recommend me as well. I think my PSU,HD,SSD,DVD drive are reusable as I always change my HD every 2 years. AMD CPU supporter for the past 13 years. Any good AMD + Mobo combo? Very light user not playing any games, but YouTube and bit torrent. Budget $500, can get the latest mobo with intel with DDR 4?
Thanks.
MoneyFace =p
Thanks.
Time to change flavour. Unless you want to wait another 365 days for AMD Zen or its excavator based Bristol Ridge APUs... Zen based APU won't come until 2017. And we also not sure if we will still see the light until then...
MoneyFace =p
$500 and don't do gaming can also consider Haswell...
IMHO just get Pentium G Haswell + H81 motherboard since you can still reuse your RAMs. Upgrade to Skylake won't make any drastic change compared to Haswell.
hachi
Quite interesting, maybe I wait for AMD Zen. Coz nowadays computer giving beep beep sound, might be ram issue, from 4 sticks down to 1 stick. Thinking of going into M.2 socket for the SSD.
I guess stick to AMD as I continue to support them.:)
