Recommend Multi USB Charger with SuperCharge
batniss
Hi,
Recommend Multi USB Charger with SuperCharge capabilities for Huawei please?
Thank you.
limcc
For multiport >2, I can't find any. As a house with 6x Huawei phones, I had been searching for months for multiport USB charger like the Aukey PA-T11, there are none.
For dual ports, actually, Type C + A, I prefer Bases BS-EU905. Noth ports support QC, A support SCP@5V@4.5A, C can charge iphone@18W. But when both ports are used simultaneously, the output will drop to 5V@2A for each. Theres a double A ports, offer the same features without C port. altough both A port can supply SCP 22.5W, it will behave the same when both ports are used. LPPL, the A+C is better as it also support USB-PD and the C port also support QC.
Bases also have a 3 ports charger, 2xA+1C. again, limitation when 2 or 3 ports are used. read the decription.
In short, no multiple ports charger can charge 2x huawei phone at SCP speed.
batniss
sad. anyway great info. Thanks
eyz
【Huawei/华为USB多口充电器快充版手机快充充电头充电器Max 22.5W】https://m.tb.cn/h.e6SXlWo?sm=793563 点击链接,再选择浏览器咑閞;或復·制这段描述¥MsvvYTXpwGl¥后到👉淘♂寳♀👈
this is the only mulit port charger they have. and it has only 1 22w port.
it's better to get multiple single port 22w charger than a multi port charger.
