Recommendation for an above average PC Build
chevalier88
Assuming I've 1.7K - 2k budget for a new Gaming PC.
What would you guys recommend? Thanks.
I've a 144hertz monitor, so I'm good on monitor.
Planning to re-use my old SSD Samsung evo 850 & old Dvd-drive.
I've windows 8.1 disc so no need OS.
SGJoe86
Are you more incline towards AMD or Intel?
With that budget, probably Ryzen 5 2700X or Intel i7-8700K w/ 16GB RAM and GTX 1070 Ti. No mention of cooling and case requirement?
chevalier88
been using intel for almost a decade. Is AMD a better choice?
Can you recommend me an average cooler and a case?
yes GTX 1070ti sound good but which brand u recommend?
SGJoe86
Performance wise, Intel edge out AMD when it comes to gaming, but not significant enough to really matter unless you're in pro-league. AMD works better as an production workhorse. I myself am building a new AMD build for myself now.
Case in point: https://www.youtube.com/watch?v=iyaqSAotL3w&t=483s
As for cooler, some good air cooler are able to perform as well as some AIOs for a fraction of its cost. Examples is Noctua NH-D15 and Cooler Master Hyper 212 Evo (currently using the CM cooler). I'm not well versed in AIOs as I'm using custom open loop for my new build.
As for graphics, brands like MSI, Gigabyte, EVGA, Palit, and Zotac just to name a few. Asus cost significantly higher than the other brands, but you'll need to google for the benchmarks. I got my EVGA GTX 1080 from Amazon US as it cost exactly the same as buying a GTX 1070 Ti here.
Case will depend if you going water or air cooling. There are performance factors involve when it comes to component cooling within the case, but there's also the aesthetics factor that is subjected to individual taste, so it's each his own. I personally am inclined towards Fractal Design, so you can consider Define R6 for water cooling, and Meshify for air cooling.
Phen8210
If it is pure gaming don't need to think, just go for intel..
If doing gaming and heavy multitasking then can consider ryzen instead.
As he said he is using a 144HZ monitor, all the more should go for intel to be able to attain as much fps as possible.
For a 2K rig, it's more flexible and you may want to state more details.
trunkss1
CPU + MB: Ryzen 2600x + B450 ~$480
GPU: GTX 1070 Ti ~$680
RAM: 16GB DDR4 2666Mhz/3000Mhz ~$260
PSU: Bronze/Gold Modular 450-550W ~$120
Case : Fractal Design Meshify C ~$130
HDD: If you need 1TB/2TB ~$60/$80
Total ballpark ~$1.7k
If budget still allows, can consider getting GTX 1080.
Ryzen 2600x comes with wraith spire cooler which is good enough for moderate OC. If heavy OC, can get something like Cryorig H7
chevalier88
Then I will go for intel... Any recommendation for Intel CPU +MB? as well as a cooler. I wanna keep my temperature for CPU as low as 35C when I game on ultra high setting.
Is water cooling system (Define R6) better than (Meshify) air cooling? My previous PC was only using stock fan so not very lasting. 2 years and game over for that pc. I'm not bothered by how it looks, gaming performing matters to me more than anything haha.
Ya, I will get 1070ti and only will get 1080 gtx if budget allows me to.
chevalier88
what does bronze/gold Modular mean for PSU? is it better to get Gold?
I will skip HDD, purely gaming so my previous old SSD EVO 850 good enough for me as well as my old dvdrom to save cost.
moomoox3
Palit gtx 1070ti dual fan selling at 588 on lazada if u got maybank card additional 40 dollar off, if not u can shake at lazada app during certain timing and hope to get 30 dollar off. Eventually u can get it at only 548/558 dollar..
chevalier88
so I will save $150 if I get it off from lazada?
singupingu
You want 35 deg while gaming? You need air cond room and overkilling your cpu cooler. Go with Cryorig R1 on Meshify C. Mesh front allow better airflow intake than the sealed front of R6. Quietness wise, it's R6 territory at the expense of some airflow.
Water cooling is not indefinitely better. More potential failure points, but it looks better and divert heat to the radiator instead of dumping into the chassis.
If gaming performance is all that matters to you, you might want an i7 instead of i5. Something like i7-8700 with MSI B360 Gaming Arctic is a good combination of performance and price.
Sent from OnePlus ONEPLUS A3003 using GAGT
chevalier88
Unfortunately, my room air-con is down and only can use fan.
So, I will get I7-8700 + msi b360 gaming arctic (572$) + Cryorig R1 on Meshify C casing ($130), best option here?
Or should I get NZXT Kraken X72 AIO cooler for better cooling on my CPU>
Palit GTX 1070Ti Dual @ $588
SSD re use my old - SSD EVO 850 <--- is it better to get a new SSD or It's fine re using my old SSD as it wouldnt affect my gaming performance even if I re use my old and useable SSD?
OS - window 8.1 64 bit.
Ram- what do you recommend? is G.Skill Ripjaws V 16GB DDR4-3200 CL14 good for this build?
PSU- what would be a good and wise choice?
Should I be getting any additional fans to keep my cpu more cooling?
Thanks.
singupingu
Intel i7-8700 is a locked cpu. No overclocking on that. Using a Cryorig R1 Universal is already overkill as that cooler is a 280mm liquid cooler equivalent. In fact, I usually recommend cryorig H7 for this kind of use case, but since you need the super low temp on gaming, only which I recommend the R1. You don't need a 360mm liquid cooler on a locked cpu. Overkilling more will only pay more for the same result. As I mentioned too, liquid cooler have multiple potential failure point. Pump fail causing overheating if not monitored, leakage will kill components like gpu. It works great, but when it fail, it fail catastrophically. Know your risk.
For Intel rig, whatever ram cheapest at 2666mhz will do. Corsair Vengeance LPX, G.Skill Ripjaw V, Klevv Bolt/Cras, Crucial Ballistix, whatever cheaper.
For PSU, you can get Seasonic Focus Plus 550W or 650W if you ever wanna upgrade to higher tier gpu like the xx80 Ti models.
Chassis have 2 stock fans. Get another 2 will do. If you can afford, 2x Corsair ML120 would be great.
Your gpu choice is weird. While you overkill your cpu temp, you plan to buy a gpu that have a very basic cooler and will likely throttle on high loads. I did mentioned on the other thread, the Jetstream model will produce better temp and performance overall.
chevalier88
CPU+MB I7-8700 + msi b360 gaming arctic (572$) + Cryorig R1 (any idea how much is this?
CASE: Meshify C casing ($130),
RAM: 2X8GB or 2x 16GB or 1x 16GB?? whatever cheapest at 2666mhz will do? It wouldnt affect my gaming performance much?
Seasonic Focus Plus gold 550W ($133) < good enough to future proof if wanna upgrade in the future? but the 650W would be additional of $10 at $143.
Corsair ML120 <any idea how much this cost for per piece?
Okay, I will get the Palit GTX 1070Ti JetStream @ $625 instead then.
singupingu
Cryorig R1 (about $130)
RAM get 2x8GB. Should be enough to run almost anything. You can upgrade to 32GB in future. Choose the RAM at the shop you're buying. Any of the brands and models I mentioned, whatever the cheapest they can offer
PSU 650W more future proof in a sense. But if you never plan to get high power expensive gpu like the xx80 Ti models, 550W is more than enough.
Corsair ML120 about $36.50 per piece from lazada is the cheapest I can find
chevalier88
Ok, I will get 2x8GB G.Skill RipJawsV 8GBx2 DDR4 2666mhz at 240$.
Corsair ML120 seem to be alittle out of budget after calculating everything I need to get is about 1.8k Is it alright to leave the addtional fans out ? It will still keep my temp below 45C while gaming right?
I might need a basic dvdrom, any recommedation? or any at cheapest price will do?
Last 2 questions, will re-using my old SSD 850 evo have any impact on my overall performance or its better to get a new SSD?
Which shop better? Tradepac Or pc themes to get my rigs>
Thanks.
