Recommendation for compact atx case
Chevalier
Hi guys, looking. For a compact atx case.
Was lookin at the raijintek Thetis
Needs to fit
a full-size atx mb
Zotac 1080ti mini
240mm aio
Preferably short in height
Would love to hear your suggestions!
Sent from HTC U11 using GAGT
FlipGor
Needs to fit
a full-size atx mb
Zotac 1080ti mini
240mm aio
Can try the coolermaster masterbox lite 5, can fit in all the parts u mentioned and is around 44cm tall, mid tower dimensions
tmfwy
Needs to fit
a full-size atx mb
Zotac 1080ti mini
240mm aio
Lian Li DK-05
Most compact of all cases coz it does not take up any space at all, except for the desk.
xonix
Your best bet is to find those cases that are designed to install the board with with directly above or below the power supply and hdd cage. This layout will allow the smallest size case.
Encrypted11
Define c/Meshify c :s34:
The case is short though,if you fit a front rad aio + longer than founders edition card, u will have trouble clearing the length.
Not an issue for zotac mini
