Recommendation For CPU Air Cooler For Haswell
sunset
Hi All,
Looking for recommendations for a cpu air cooler for haswell 4770. Looking to build another rig to put in my gf's place so that when i go over, i have a rig to use for video rendering and gaming.
I will be using these parts and would appreciate if any guru here can help me fill in the pricing of these. Looking to buy from tradepac.
1) i7 4770 + Gigabyte GA-H87-D3H $426
2) Gigabyte GTX 760 $393
3) Corsair Vegeance Pro Series 16GB $??? (With the recent increased ram price, anybody know what's the current price? And if the air cooler recommended would be able to fit?)
4) Corsair CX600M Power Supply
5) Plextor M5 Pro 128GB SSD $???
6) Toshiba 3TB HDD $???
Since the rig will be at her place, i will let her decide on the case.
Thanks in advance!
shadow84
Change PSU to seasonic or FSP.... Something like seasonic m12ii 550w
Can get WD Blue/black 3tb...
That ram is quite high, may conflict.
For CPU cooler, can try to find Xigmatek Gaia, dun get the Gaia II. Pain in the @ss to install.
And where you get i7 4770 + GA-H87-D3H to be $426? it's $527....
sunset
cool. any idea on the pricings? if the rams are too high, any good low profile ones to recommend?
shadow84
Can get like g.skill or kingston value ram... should b low enough since no heatsink... or if u wan a bit of bling bling, go order avexir rams online. But is 16gb really needed?
sunset
Hmm.. The more the merrier.. :s13:
shadow84
nobody have recommendation for cpu air cooler?
120/140mm: Antec kuhler 920, thermaltake 3.0 pro/performer, nzxt x40, cm seidon 120m/120xl
240/280mm: thermaltake 3.0 extreme, nzxt x60, cm seidon 240m
Most perform roughly the same, within 1-3 degrees diff... so just get a cheap 1 will do. not as if the more expensive model will work better.
lucian90
try something from noctua lor
Noctua.at - sound-optimised premium components "Designed in Austria"!
eminus
Phanteks
http://forums.vr-zone.com/hardware-depot/2591525-review-phanteks-ph-tc14pe-aerospace-technology-comes-your-cooler.html
x3illuminate
Those all like water cooling leh,he asked for aircooling wor
Get one of those CMhyper212+/evo, relatively cheap and good performance
royfrosty
Aiyo why so difficult? Just get a xigmatek Gaia 1 a will do. Get so many heatsink all still perform the same.
The_King
i am getting this for my haswell.
the only part i wanted warranty is motherboard asus z87 gryphon and ram
cpu maybe locally,
gpu will be from amazon
