windwaver
- Apr 28, 2000
In that case, what other brands can I consider? Asus?no more MAIBENBEN from me.
unless they up their QC.
The reason why I find flexibility in my older larger mATX system is because when components fail e.g. RAM or mobo, I can easily replace the faulty piece.
There's no flexibility in such tiny systems right? Correct me if I'm wrong because it's been so long since I look at buying a system.
To make it small, there will certainly be some trade off in terms of upgradability. The motherboard is usually custom sized and something that you can't buy off the shelves. The most flexible "Tiny PC" is the Asrock Desk Mini where you have the flexibility of buying/ replacing your CPU, in addition to the RAM, SSD and WIFI card that are generally replaceable. But it is not cheap for the full setup.The reason why I find flexibility in my older larger mATX system is because when components fail e.g. RAM or mobo, I can easily replace the faulty piece.
Well, PBO set to 45W, apparently the motherboard doesn't give a s***
Lowering TDC and EDC did the trick tho. Now I have to worry about the SOC. Oh well baby steps.
Glad I do testing with a normal PSU first
Will try later. Currently the AMD extensive and confusing settings seem to be working out.there is another setting in bios, iirc settings - amd cbs - nbio - smu options - am4 system
there are options to select 35w or 65w.
not sure if it works![]()
Didn't work. Set 35W still reach 70W with prime+furmark.there is another setting in bios, iirc settings - amd cbs - nbio - smu options - am4 system
