Recommendation for DIY build
panda_hippo
I am planning to get a new computer for 1440p 144hz gaming. Not planning to do any overclocking. My budget is around $1500 (will be great if it can go lower). I would like some advice on the components:
Processor: Intel Core i5-7500
Motherboard: Not sure, please advise
Memory: Prefer high clock speed DDR4 (2 x 8GB)
Graphics card: GTX 1070, please recommend the brand
Storage: Plextor M5 Pro Xtreme 256GB (Reuse from current system)
Optical drive: LG GH22NS40 (Reuse from current system)
Casing: Looking at CM Masterbox 5/NZXT S340 Elite/Fractal Design Define S
Power supply unit: Not sure, please advise
Audio: ASUS Essence STX II
Rashkae
1. For CPU/Mobo I'd recommend also looking at Ryzen. ;)
2. For DDR4, if you look at the tests, anything above 3000 does not offer performance improvements - you can save some money here.
3. Get a Zotac here from HWZ, the 1070 in the SG shops is crazy expensive.
panda_hippo
My current computer is already down, I can't afford to wait as I use it for work too.
Thanks for the tips though, I will look at the Zotac.
singupingu
Zotac lobang for you. Go Qoo10 apply 2% shop coupon and $100 cart coupon.
Sent from Overpowered Phone Mark III using GAGT
Krabs.
i5-7500 can sustain that high FPS in cpu intensive games ? :s11:
