Recommendation for home projector
xiaobaizhu
Hey peeps,
I'm looking to get a projector for my new place and would love your recommendations and advice!
Projector (800 to 1500)
- LED greatly preferred
- Ceiling mounted, 3m throw
- 1080p if possible
Mount (would like to find out the ballpark for both the mount and installation)
- Ceiling mounted
- Adjustable height and tilt
Sidenote: does anyone have experience with the Singapore brand innovative? They look pretty decent for the price, but would like some user reviews.
Thanks!
Ps, typing on phone, please pardon the mistakes!
86technie
At your budget for HD projection not possible.
Below $2k, you can only get WVGA which has only resolution
of 1333 pixels only with installation.
For FHD, at the most $5k. Projector itself cost $2-3k, HDMI
cabling, FHD projection screen and etc. will total up to $5k.
Rather just get a FHD/4K TV and mount on the wall.
More cost effective than projection and do also
your room got to be large enough to support it.
Here's a good guide, take note of the viewing distance.
http://www.whathifi.com/advice/how-to-set-your-tv-and-get-best-picture
At least you must have 1.7m for projection.
The viewing distance will play a crucial part in determine
what TV size suitable.
Hope this helps.
flikmy
Hey peeps,
- 1080p if possible
- Ceiling mounted
Thanks!
Think you can get the Benq W1070+ for under $1500.
See link for rough price http://projector.com.sg/index.php?main_page=product_info&cPath=1_6&products_id=1041
Believe it's meant to be one of the best value 1080p projectors in it's class.
Supersen
Hi guys, was looking at the Singapore brand innovative too at SLS for the model T7 Kodex Streaming Projector
any reviews on the brand innovative for office meeting room use?
86technie
This model is more for home use rather than office use.
Office use there are low cost models but not advisable.
As projectors are unlike TV, they are prone to failure
even due to users fault.
Such as user vandalism, didn't let the projector cool down
before switching off, power trip, overheat due to didn't switch off
and etc.
Projector is a very fragile equipment, for business use.
Get proper projector with maintenance contract.
May cost you about $1.5k to $2k but in the long run
it is more worth it.
Don't solely make decision based on cost itself when buying projectors
as it is not that simple.
And also remember that you are not only the one using it but
many.
Cheers.
Alienwaree
Suspended
anyone knows if it's worth it to purchase those small, portable projector from Taobao? less than 100SGD kind. https://www.shopback.sg/taobao now up to 12% cashback. Might want to try and get the projector from taobao instead of lazada.
86technie
As quoted above, the cheaper the projector the lousier
the quality.
Whether the LENS, circuit and etc.
The cheaper it is, just prepared to buy a new one soon.
