Recommendation for Laptop for Adobe Suite
WoXingWoShu
Hi pros,
I would like to get some recommendations for laptops that is good for Adobe Suite (Photoshop, Illustrator) use.
Preferably a big screen and under $2k if possible.
Thanks in advance.
Kenshin79
most 15.6" laptop would fit your needs.
main considerations:
CPU - Dual Core (lighter notebook) or Quad Core (heavier)
RAM - 8GB is fine
HDD - 1TB HDD or if have SSD is great
Screen - 15.6" FHD is good
Graphics - this is actually not so critical for Adobe suite. any dedicated graphics is good. Processing power & RAM are more important for Adobe.
Lightweight ones:
ASUS K501UX-DM079T
i7-6500U (dual core), 8GB RAM, 128GB SSD + 1TB HDD, 15.6" FHD, nVidia GeForce GTX 950M 4GB, Win10 Home, 2 Years Warranty, 2Kg
$1498
ASUS K501UB-DM097T
i7-6500U (dual core), 8GB RAM, 1TB HDD, 15.6" FHD, nVidia GeForce GT940M 2GB, Win10 Home, 2 Years Warranty, 2Kg
$1298
ASUS X550
i7-6700HQ (Quad Core), 8GB RAM, 1TB HDD, DVD-RW, 15.6" FHD, nVidia GeForce GTX 950M 4GB, Win10 Home, 2 Years Warranty, 2.4Kg
$1398
ASUS GL552
i7-6700HQ (Quad Core), 16GB RAM, 128GB SSD + 1TB HDD, Blu-RAY/DVD-RW, 15.6" FHD, nVidia GeForce GTX 960M 4GB, Win10 Home, 2 Years Warranty, 2.4Kg
$2098
WoXingWoShu
Thank you for the recommendations.
Any particular reasons for recommending just Asus? Are other brands not good?
