Recommendation for light laptop
revebek
Hi experts,
looking for recommendations for a laptop that I can bring around for business (local and travel) to do presentation (and maybe some light coding).
here are some features i would like to have:
1. Touchscreen & Pen support (as i do annotations, now need to use separate iPad)
2. Good battery life (for travel)
3. Lightweight
4. HDMI port (don't like dongles)
5. has USB A and C ports
Good to have features
6. 1080 camera
7. discrete GPU
Budget wise, would like to get something around 2k or less. But considering discrete GPU maybe have to go higher budget
I somewhat refined to a few models:
1. Apple MBA (no touchscreen, macOS)
2. Thinkpad Yoga / Lenovo Yoga
3. Asus zenbook 14x
Which one will you recommend or any other recommendations welcomed as well.
thank you very much.
blues7
was at dell
their xps not bad, has touchscreen
of course, not so budget friendly
pay more but the build is good
find apple macbook ok if you need something light to carry around, no need touchscreen, it is not that easy to touch screen, unless iPad, then get iPad
NightRaven49
3. Asus zenbook 14x
i would say the thinkpad x13 amd g4 is the best fit. right now got 1 model for just under 2k, has everything u want except a discrete gpu, the latest and greatest ryzen 7840u with pretty decent integrated graphics, 32gb of ram, 1tb nvme and 3y of warranty. the macbook air is also decent if u prefer macos and have a strong focus on battery life, but keep in mind there is not only no touchscreen as u noted but also no hdmi or even usb a ports, so dongles are absolutely necessary. they are also very expensive brand new, with 2k budget only netting u either a 16gb ram + 512gb storage or 8gb ram + 1tb storage for the older m1 variant (with a worse 720p webcam) or if u want m2 only either the 16gb ram or 512gb storage upgrade (both or just a 1tb storage upgrade would be 2.2k). the zenbook is quite a bit over the 2k budget and is the heaviest of the bunch at over 1.5kg compared to around 1.2kg for the x13 and mba, and with the default 13900h and discrete gpu, i dont have high hopes for the battery life.
revebek
Thank you. Let me check out the x13!
revebek
I did some research on the thinkpads and come to a few choices:
1. Thinkpad X13 Gen 4 AMD
2. Thinkpad T14 Gen 4 AMD
3. Thinkpad T14s Gen 4 AMD
currently tilting towards T14s.
Any expert here can let me know from trying it, the T14s vs T14?, which is better in your opinion?
firesong
Deluxe Member
I'm biased towards the Ts series over the normal T. The Ts series has better materials, so a better build quality.
Since the T14 (first gen), the non-s T series have been made with plastic rather than carbon fibre, and it's not nice feeling.
Go with the Ryzen 7 series because of their RDNA2/3 iGPUs. It's a much better experience than anything from Intel atm. The 780M is almost equivalent to a 1650Ti mobile in benchmarks, so that says quite a bit considering it's integrated.
Just note that the RAM is soldered, so you'll want to max it to 32GB if your budget allows.
If GPU isn't a consideration, try the 2in1 LG Gram. It's also quite the beast, but has inferior Intel Xe graphics. It's lighter than the Thinkpad tho.
revebek
thank you i'm looking at T14s now over X13.
For display i see there's a option for touch screen 500 nits. But it comes with eprivacy filter. I read online that even if you can toggle the filter off, it still makes the screen bad for viewing.
Does anyone has any experience with this? eprivacy filter? How is it?
firesong
Deluxe Member
Haven't seen it, but so far most say it's about as bright as a 300nit screen in actual use.
I'd go with the low power 400nit panels if I remain on FHD. They're a decent solution overall, and offer the best compromise across the board - good brightness, sufficient resolution, good colours.
BlackCube
Abit interested in Thinkpad T14s Gen 4 AMD
At the build pc there, it states "No Wireless WAN", then if changed to "Fibocom L860-GL-16 4G LTE CAT16", add 224$. it mean the laptop dont come with wifi? have to add 200 for it to come with wifi?
Also, the display got so many pattern, which one to go for? - saw the 400nits discussion above
I don't quite like the red tracking at the middle of the keyboard though..
NightRaven49
no, wireless wan refers to sim card support for 4g cellular data. wifi is already included, in the wireless section just above the wireless wan selection, stated is qualcomm nfa725a.
revebek
Thank you. I will consider the 400 nits, the downside is for t14s the 400nits will not have touch.
Although i'm not currently using any touch laptops, but i'm seeing the use-cases as i use iPad on a daily basis. Having one device to write on and use as laptop could be useful.
revebek
the red trackpoint is a signature for ThinkPad. I've seen expert users in the past using it and it's amazing how precise it can get versus the trackpad. Myself however, having owned a ThinkPad previously, i didn't use it, still using mouse. 🤣
BlackCube
yeah. I'm not a track user too. prefer mouse.
I just saw this model in Harvey, 1.9k
Read HWZ Forum Rules!
revebek
you mean T14s? on lenovo official the price can range from 1.6 to 2k depending on screen selection.
I went to bugis junction lenovo store but they didn't have any display units for T14s and also screen configuration (especially with eprivacy filter), i think need to go to funan to try my luck. 🤣
revebek
Decided on x1 carbon eventually. checks all the boxes but break the budget by a little. Intel U processor though..
xiaomao87
Hi experts,
3. Lightweight
6. 1080 camera
7. discrete GPU
3. Asus zenbook 14x
New Asus ZenBook s13 OLED
Not bad choice
Lightweight+ port
I'm also considering
M1 MBA (no use mice)
MacBook 12 inch 2017 (no wifi6) no use mice
Asus ZenBook s13
Now I'm using Lenovo x1 nano wear and tear haiyaaaa
Now I consider what is imp to me sia
revebek
Not bad choice
Lightweight+ port
Asus ZenBook s13
this is actually my 2nd x1. The first one i have is still functioning fine, but i pass to my wife to use. And I lug around a legion 5 for 1 year. Now I want to go back to lightweight so bought x1 again, but not before seriously considering the other mighty contenders like zenbook 14x, ThinkPad 14s and x13 🤣
