Recommendation for MacBook Air 11" battery
Chips
Hi anyone can recommend a place in singapore to buy Macbook Air 11" (2011 model) replacement battery. I want to try replacing it myself to reduce the cost. I understand to do it from Apple service centre will cost close to $400.
Hopefully to get OEM original battery instead of 3rd party 1
mjboon
Hi, you can take a look at ifixit. But think you will also need the T5 Torx Screwdriver and MacBook Pro and Air 5-Point Pentalobe Screwdriver. (I plan to replace my MBA 13" battery as well) ...
MacBook Air 11" (Mid 2011/Mid 2012) Battery (661-6068) - iFixit
Chips
thanks! seem like ifixit is cheaper than getting it on amazon. Amazon's battery price is about the same but shipping is quite high
geckoSG
chips. Once u done it, let me know the total damage n ur experience if it is easy to do so. Think I might want to change mine too
Chips
i got the battery already about $192 (battery, tools and shipping) i haven't had the chance to change it yet maybe i will do it after maverick is released
Chips
it is really easy to do it. basically just take out 8 screws, pop open the back cover, take out 4 screws and the battery connector then just put in the new battery and reverse all the steps. took me only like 5 mins to do it
taffyong
anyone planning to buy online from ifixit? I figure we order together to save on the shipping cost. anyone?
galliano
Battery also getting super lousy, despite having only 317 cycles since i bought this.
Mine's a mid 2011 MBA w 128Gb, 4Gb Ram.
Any suggestions on where to get battery replacement? Or even if its worth getting one already.
Saw on http://www.macinfinity.sg/#!macbook-repair/c1ks4
Its $190 for battery replacement. Siong.
msfluffycloud
issues
My macbook air is facing some issues with its software, it keeps lagging when im using it. May i get some advice??
I still am under apple care, shld i go get it checked by them?
