Recommendation for mini itx budget build
sensod
Already have these components: elite 130 case, ssd, hdd, keyboard, mouse, monitor.
Usage: mainly for parents, YouTube, Facebook, internet surfing, light gaming, no gpu required
Thanks
hellspawn_one
CPU & Mobo: intel i5 8500 & MSI B360i Gaming Pro AC (come with wifi) ($481)
PSU: Seasonic S12-II 520W ($89) or FSP Hyper K 500W ($69)
Ram: KLEVV DDR4 3000Mhz 2x8GB ($238)
Prices listed are taken from Cybermind, you might find cheaper price elsewhere
singupingu
Alternatively, can opt for Ryzen if you want better gaming experience, as the integrated GPU from Ryzen APU series is better performance than Intel UHD. For the usage you stated, I don't think you need Intel Core i5.
ASROCK AB350 Gaming ITX + AMD Ryzen 2200G: $312 from PC Themes.
The rest can follow the above.
Sent from OnePlus ONEPLUS A3003 using GAGT
sensod
Thanks guys. Appreciate it. Think will go for amd as it is cheaper, in fact it is my first amd buy for as long as i can remember, been using intel for ages.
singupingu
There's nothing wrong with going Intel. But the i5 is a bit overkill for a parents' web surfing pc. Plus if you wanna do some occasional light duty gaming like esports games (Dota2, CS:GO, L4D2, LOL, Overwatch) for casual, then Ryzen APU will fit your usage much more than an Intel i5, though the i5 have much better compute power, but that's proven redundant for your use case.
Plus a 8gb ram is sufficient
Sent from Sony H8166 using GAGT
