Recommendation for pc build for 2.5-3k
GhostWhere29
Hi all,
I was planning to build a PC in feb, but hold back till date.
What is the current recommendation for gaming for CSGO, NBA2k21 in high FPS?
Current monitor is Prism+ X270, looking to upgrade to 1440 or 4k. (excluded in my budget)
Please help me with best lobang if possible. Thanks in advance!
Yongkit
It would be great if you could mentioned on your budget limitations and if any preference on Intel or AMD?
GhostWhere29
thank you for the reply.
my budget is about 2.5k - 3.3k
was looking at AMD 5600x, Intel is fine too as long as it is worth it.
SkyShroud
CPU: AMD Ryzen 5600x - $407
MB: Asrock B550M Steel Legend - $200 (Any local store)
CPU Cooler: Hyper 212x - $59 or anything really, can get cheap 212(no x) at $40 at shopee
Ram: 2x8gb 3200mhz cl16 - $140
Nvme SSD: 2tb Sabrent Rocket or Adata SX8200 or MP34 or Intel 760p or.....check this - $350 to $400
PSU: Any 10 years warranty gold rating minimum 650w - $170
Wow, you still got 1.6k budget for nice GPU and casing!
GPU pricing is really hard to tell now.....
With remaining budget, you could get gtx 3070 at best or 3060 at worst
Yongkit
The following suggestion was based on your current monitor tech (freesync) and game you play (non RT specific)
Ryzen 5 5600X + Asus TUF B550-Plus Gaming Wifi (DYNAcore)
CM HYPER 212 LED Turbo ARGB CPU Cooler (Fuwell)
Corsair V.Pro SL RGB 3600MHz CL18 - 16GB (DYNAcore)
Samsung 980 M.2 NVMe - 500GB (OS) (DYNAcore)
Asus Amd Radeon Rog Strix RX 6700 XT 12Gb OC GDDR6 (DYNAcore)
Seasonic Focus GX-750W Gold Modular (DYNAcore)
Phanteks Eclipse P500A Digital RGB TG ATX (DYNAcore)
for your consideration and please do also considered the good suggestions from other members too as everyone have different preference.
Wishing you Happy Hunting :)
GhostWhere29
Hi all,
I have purchased my build with the help of you people and grateful for all the help. Please help to review my build if have time please.
Ryzen 5 5600X
B550M GIGABYTE DS3H
240MM TECWARE MIRAGE AIO WATERCOOLING
Nvidia RTX 3070 ZOTAC TWIN EDGE OC(LHR)
1TB ADATA XPG SX8200P NVME SSD GEN3
2TB P300 TOSHIBA
16GB ADATA XPG D60G 3200mhz
750W EVGA GA750 GOLD FULL MODULAR PSU
NZXT H510 ATX CHASSIS (BLACK)
240MM TECWARE MIRAGE AIO WATERCOOLING is unable to sync with Gigabyte Fusion 2.0.
Anyone can help me on how to change the ARGB with software?
Thank in advance!
GhostWhere29
Hi,
Please help!
Is 240MM TECWARE MIRAGE AIO WATERCOOLING compatible with B550M GIGABYTE DS3H?
Tried Gigabyte Fusion 2.0 to turn off all light but its not working.
AIO doesnt seem be detected by Gigabyte Fusion 2.0.
Thank in advance!
Proximus
RGB Fusion is crap. Try OpenRGB.
RGB on Gigabyte boards will not switch off if PC goes into sleep/hibernate mode using Openrgb.
Have logged a ticket with the developers of Openrgb but they say it is something beyonf them. Only Fusion can switch off the rgb.
