Recommendation for replacement motherboard
zaapiez
Hi all,
Recently my motherboard has been giving me issue. Would like some recommendation on replacing it.
Any idea if i can transfer my win10 key to my new mobo?
Processor
i5 4570
Mainboard
Asrock B85m - Pro
Graphics Card
Zotac GTX 970
Memory
Kingston DDR3 4Gb x 2
Casing
Fractal Design R4
PSU
FSP 550 Plat
OS
Windows 10
ZrE0_Cha0s
well i rmb that they say once ur win 10 is linked to your account you can use it on the same pc. but not sure how would it affect if u change another mobo.
but may i ask whats the issues with your mobo?
zaapiez
This issue
Motherboard already OOW, some of my friends using the same board also facing the same issue..
Koenig168
Hi all,
no, ur win10 key is bind to your hardware, especially mobo
Technically, the Win 10 is tied to hardware and a MB change will require a new key.
No harm trying though. I managed to transfer the Win 10 Pro from my previous MB to the present one with all other components (except MB and GPU) remaining the same.
zaapiez
hmm is the same chipset? i think same chipset should be easy to talk to microsoft..
