Recommendation for Stick/NUC PC
jk_eugenetay
As per title...
Preferably default with OS, need not be high performance.
Considering the latest Asus Vivostick.
Anyone with actual usage experience to share and recommend?
Using this for minimal web browsing & doc processing terminal in retail environment
MacClipper
wwenze
Get the biggest stick/box you can
Cooling will be the thing limiting performance, not whatever Cherry Trail CPU they use inside
leongws
I just bought 1 MSI mini PC last week. Bought the lowest end and comes with intel celeron 3250u, 64Gb msata SSD, 2Gb ram, with wifi AC + bluetooth(also comes with Gigabit LAN port) 1 HDMI and 1 Mini displayport output and windows 8.1 at below $400. However i added extra 8Gb ram and installed another 2.5" 500Gb hdd which i was using as external HDD previously. Also updated to windows 10 with the free upgrade.
Overall to surf net watch video & word processing, it is more than enough. It boots up and shutdown real fast with the 64Gb msata SSD.
hawthorne
I'm using the NUC5PPYH primarily as a HTPC. So far so good.
But some video streaming sites gets close to 100% CPU cycle. Video is watchable though. There is 1 instance where a video streaming site gets 100% CPU cycle and becomes choppy/ unresponsive.
"normal" Web browsing wise, NUC5PPYH shld be enuf. Might want to consider the i5 or even i7 ones if your application is intensive.
hysteriakx
how does the intel compute stick compare with the nuc? the refreshed atom ones. not the m core
jk_eugenetay
I read reviews about the 2016 edition of Intel compute stick... can't do word processing well. Any user experience?
Cheapest USD99
Best Value for $$$ around USD200
2016 Version of Intel Compute Stick
You watch all 3x Video Review and then you decide yourself which one you want bah.
Zabiyaki
The kangaroo has an upgrade to 4gb ram..think 160 bucks? Falls between the Voyo n 99$ kangaroo
Voyo v3 is better lah.
USD200 comes with better x7 CPU, 4GB RAM, 128GB SSD and Win10.
4GB Kangaroo boh OS and 64GB only and using x5 CPU.
