Swordsman
- Jan 27, 2002
$1k is the max. i will use back the psu gfx and storage. a partial new system.The spec can handle the games so maybe Windows have issue so you can try
do a clean install. (Not reset).
If you want to do a new system what is your budget?
FYI if you want best gaming performance, I recommend MATX setup would be better than ITX
mainly due to heat.
16 gb 3200 mhz good enough ?game lag because you use 8GB ram. try buying another 8GB for $40 before spending more
also nowdays for no reason, pc auto restart on its own quite frequently.. one of the hardware is faulty.. but dunno is which.game lag because you use 8GB ram. try buying another 8GB for $40 before spending more
auto restart is psu or ram. try replace those 2 first.also nowdays for no reason, pc auto restart on its own quite frequently.. one of the hardware is faulty.. but dunno is which.
5800x+x570 mobo. about 800$1k is the max. i will use back the psu gfx and storage. a partial new system.
changing the cpu, ram, mobo, casing
sorry i failed to mentioned, now quite often the pc will auto restart on it own. its an hardware failure but i don't know which.
In my experience CPU upgrade can help alot in games. 2 years back I upgraded from i5 4690 to Ryzen 3600, with same card gtx1070ti.
Massive improvement in most games in terms of how smooth the game runs. So I think my old CPU really bottlenecks the system.
IT noob.. go where to see event viewer ?maybe u can see your event viewer and screenshot to paste here.
wow. thanks. so many possibilities that can be faulty.System restarts can be:
- RAM
Run Memtest when you have the time.
- SSD
Run Crystalmark if it reboots/crash that means SSD have issue.
- Power supply
- Windows
somtimes.. auto restart, then stuck at dark screen.. cpu light is on.. gotta off and on several times before able to reach mobo logo screen.auto restart is psu or ram. try replace those 2 first.
When i was using cooler master, it randomly hang, rma successfully and sold off that **** brand
wah not cheap siah.5800x+x570 mobo. about 800
add $300 for ram
it is what it is..wah not cheap siah.
