Hi wwenze, thanks for your information. I am a noob in audio stuff.
I am looking for a unit with radio, can play MP3 from USB thumbdrive, as well the TV sound can goes through it which will be using the system speakers to enhance the sound output (not sure if it is the correct description for the TV part)...
Based on your reply below with regards to TV, what is the difference?
Will it be receiving signal from the TV with just one cable, or will all the different sources connect to it while it connects to the TV? If it is the latter, you need an AVR
For speakers, I am looking at max of 3, one front and 2 side.. but my living room is small, so maybe 2 front speakers is enough.
Saw this unit, but my friend told me it has no radio receiver.
http://www.lazada.sg/marantz-stereo-integrated-amplifier-hd-amp1-silver-11430011.html
Budget is flexible. Even though im noob, i do appreciate good sound, but between good and excellent well I do not think I am good enough to discern the difference.
