Recommendation required for 3 Hardware
g3n3tic_twig
Hi fellows,
Would like recommendations for 3 hardwares for gaming for fifa 14 and future fifa releases (maybe till fifa 15-16).
- Mobo
- CPU
- GPU
Hope you all can help.
jgyy1990
Can indicate ur budget mah. Or else I jitao recommend r9 280x for gpu.
zenniz
If you wanna play the game at lowest setting with 60fps, your minimum budget must at least be $250 for all three hardware.
royfrosty
As budget as possible.
asrock b75m dgs + i5-3350p ~ $271
Powercolor 7870 2gb ghz edition ~ $241
Add $20 for non full rig setup
total ~ $532 buy at tradepac. Diy
zenniz
So it'll be $750 for just these 3 hardware?
Fifa 14 only leh?
I mean a total of $250 for all 3 hardware if you want to play fifa 14 at the shittest and lowest graphic setting. Trust me, it will look total crap if you run it at the lowest. Medium setting will sets you at minium of $450.
