Recommendations for aio cooler
KarmaKarma
Max length 280mm
Radiator max thickness 50mm
Shortlisted a few myself
Corsair h115i platinum
Nzxt z63
Asus ryuo 240mm
Using air-cooler now, but temps are hitting 70-80 while gaming. Anymore recommendations? Thanks everyone!
Sent from Asus ROG_PhoneII using GAGT
hg2
Temps looks acceptable leg!
Personally, only recommend AIO for high TDP CPUs (i9/Ryzen9/TR) to preventing peaking at 99c and smooth the heat saturations...
shadey
70-80 while gaming is fine. If you're worried, do a -0.05v tweak
KarmaKarma
I read online they say best keep away from 80 leh so I was thinking of getting an aio
xonix
For Intel or Ryzen/Threadripper ?
Do note some AIO don't come am4 or threadripper brackets.
shadey
CPU will auto throttle at 95c, so that's what you want to avoid. 80c under gaming load is ok.
