Recommendations for case fans
Chevalier
Looking to build a quiet / silent build.
Which 120mm case fans would you guys recommend? Open to buying local and from Newegg /amazon.
Moi do not use any fans or filters.
Quarterly I just use my leaf blower for 15 mins.
Psycovirus
5 fans for $48 on Prime Now. It says low noise. I only use the 80mm version before. Those are quiet enough for NAS storage fans. Reviews looks good.
shadey
Noctua or BeQuiet! are the best options.
FYI: You can google for "120mm case fan review" and there's a lot of good data on airflow vs noise etc.
Tan Gee Ming
wah 1 fan cost $9.60 + shipping fee. so xx.
shadow84
Gentle typhoon AP-15 1850rpm pwm fans. Shld be going for $28+/- from taobao. The more u buy, the more u save on shipping per fan. Each cost ard $25.
averdant
Arctic fans if you're on a budget.
Noctua/gentle typhoon if you want higher end stuff.
wwenze
$25 fans
I cringe
Buy 4 = can get a better class GPU / CPU liao and then just undervolt it
