Recommendations for gaming headset
whysoserioushuh
bro you just replied to a shopee bot LOL.
i used the logitech pro x at my friend's house. it's actually really comfortable and the mic quality is better than mh752 imo (and mh752 mic quality is alr one of the better ones among gaming headsets imo). and you can't go wrong with logitech build quality lol
still if you want comfort right, i suggest you go for a IEM + those $40-50 podcast mic. that is definitely the best setup for comfort.
Wah nb lol. Also have bot here one ah? Yea logitech gears are built to last. I will still go headsets cause I'm used to it already.
Ok, shall go logitech pro! Money can earn back. Lol
Sent from Samsung SM-G975F using GAGT
My current setup after hours of research and money burnt for testing
1) 1More Triple Driver Earbuds
2) Samson Q2U Mic
Good Sound, Great Comfort, Great Mic
rizzvibe
did quite extensive research previously, shortlisted Hyperx Cloud Orbit S and Audeze Mobius due to the planar magnetic drivers but ended up with Coolermaster MH752 and not regretting it except the 7.1 Virtual Surround Sound pretty useless. Sound is decent enough for music/gaming, very comfortable and mic is great! Just my 2 cents.
for ur budget, can look at Coolermaster MH751/MH752, Steelseries Arctis 3 or Logitech G Pro.
whysoserioushuh
Any difference between G Pro and G Pro X?
UptheToon
i using logitech G933. 7.1 surround.
the surround is really really good and very comfortable. thought it's pricey coming in at around $220+.
whysoserioushuh
This is wireless right?
I used wireless before. Just dont like to keep switching batteries.
rizzvibe
reckoned its almost the same. but based on specs, the differences seem to be the driver, material used and the "blue voice" gimmick which reviewers mentioned on the Pro X. aesthetically Pro X looks better also.
was deciding btw MH752 and Pro X, but prefers mic to be detachable and its cheaper also. got it at shopee @ ard 117 after vouchers etc. anyway if its for gaming, as long as its decent, it'll be fine, goes with one you deem suitable.
whysoserioushuh
Yea, im actually checking these 2 out. MH752 and Pro X. My only few criteria are a proper mic, comfortable if i wear them for long hours. Mostly using for FPS gaming, probably abit of music and thats about it.
rizzvibe
yea, got it for csgo as well. some youtube reviews may help u decide. Sound wise don bother cos audio is personal and subjective. Both def not for critical music listening but pretty good at this price lvl. Pro X def looks sleeker with the material but may burst ur budget. Up to u to justify the value for another 100bucks. I'll choose Pro X btw the 2 if no budget constrain.
whysoserioushuh
Max I can go is 200. I wouldn't want to spend too much on something I regret later. HyperX was a good buy till the rubber finishing failed me. Used it for a good solid 4 years before I gave up on it
XseanX
If I not wrong, X got bluevoice and 7.1
Most decent wireless headset should have ample amount of playtime (Ard 12-15hrs) which should be enough for day to day use.
Like my Astro A50 gen 4, once done using it, i will just leave it in the charging stand, next time i pick it up will be fully charged.
xJoker
Sennheiser Game Zero. Been using it for the past 4 yrs. Only change the audio cable and also to a valor ear pad once due to wear and tear. Sounds good and pretty comfortable for my big head.
halocast
Using kraken X other than the "leather" material which is common among the gaming headsets..
Its pretty good for the price :)
EmPtYsOuLz
Just bought the Steelseries Arctis 1 wireless and been using it for work teleconference and gaming
Not bad quite happy with it, build is partly plastic so will see how long it lasts
Sound is decent and is pretty comfortable with glasses
Battery life says 16 hours and I've been getting 10hrs comfortably (don't wanna fully drain it)
noelnoel
Any lag during gaming for wireless?
