Experts, any recommendations for the above? I just OC my W3520 from multiplyer 20 to 21 for a boost of 2.66 to 2.8. No tweaks to voltage.
THanks!![]()
Can barely find any AIO cooler for the chipset already. Most new coolers are now from AM2 boards and above.
Some of the AIO cooler on the market just on par with high end air cooler.......and some are not even on par with air cooler......
so....choice is yrs to make. As long as u r happy with it. Why not?![]()
Ok la. I checked most of the AIO coolers still support 1366 Heng ah..... Looking at the zalman lq310 (119) but mixed reviews on net.... range from bang for bucks to outright waste of money![]()
Isnt 1366 intel chipset?
Are you looking for your AMD or intel?
Ya the Intel LGA1366 i7-920 (mine the "server" version or watever i had been told). Been using the rig for like 3-5yrs (i even forgot when i bought it)
Chey i thought you refering to your rig profile.
Your rig profile cannot find le.
LGA1366 still can find. I have the Corsair H75 120mm. If you want can PM me.
But lets say you wanna have everything new then $120 can land you a few 120mm AIO.
Thermaltake Pro 3.0, CM Seidon 120M.
