Recommendations for Mini PC?
zzxxzzxx
Currently thinking should I get a Mini PC that can mount to the back of the monitor easily.
Using a 10years old laptop (Asus)and a work laptop (HP) connected to an old 24” monitor.
Not using much for the old Asus. And not really intending to keep using work laptop for personal use.
Do travel one to 3 times a year for work/projects. Anything from 1 week to 2 months at a time.
Have no issue getting from TB or PDD from China. So looking for some help to select which type. Not gaming, but most likely the system will be on 24/7.
Intel N95/100/150 is slower with Single DDR RAM.
Also saw some Intel/AMD models.
Particularly this one from HAITA (海塔) brand.
Intel i7-1365U/1360P
Dual 2.5G LAN
32GB DDR5 RAM (8/16/32)
512GB NVME (256/512/1T/2T)
HDMI 2.0 / DP 1.4 / TB4 (Triple Output)
Wifi 6E
BT 5.3
32/512 is RMB 1945/2045 based on the 2 different processor.
ichinisan
Dual 2.5G LAN
Wifi 6E
BT 5.3
Specs look good. But not sure about this brand.
zzxxzzxx
I’m looking at dual 2.5GB Ethernet & Dual DDR RAM for better iGPU speed.
This makes the system feel less slow in the future (5 years down)
Mrtesting
Looking for a mini pc which is sufficient enough for regular daily usage. Web browsing, movies, YouTube, MS office etc.
Budget would be around $150 to $250.
Is it also possible to use my current HDD in my PC on the mini PC? Some mini PCs have a slot for the HDD right?
Go sim lim go find those hp elite $200+ can get 2nd hand
caterham7
Dual 2.5G LAN
Wifi 6E
BT 5.3
$439 mac mini m2, but currently oos
https://www.apple.com/sg/shop/refurbished/mac
Hello_Kitty
no need buy mini PC, just use your existing samsung phone dex feature
zueinder
I have been using mini pcs for a while and find that those in $200-300 can't seem to last. Sweet spot is around $500 to $600.
