Recommendations for MVNOs for Roaming
cj2502
Hi guys, need a recommendation for a NVMO for Malaysia roaming.
Its for my car android headunit, just needs data for Waze, Spotify, Netflix etc. I am currently using Simba SuperRoam MY at $13 per month. Connectivity in Singapore is relatively ok, only suffers a bit around BKE/SLE area.
Connectivity in Malaysia is crap though, 70% of the time there is no connection along areas like Pasir Gudang Highway, even B Point just after Msia checkpoint.
Anyone familiar with the NVMOs and roaming in Malaysia can share your recommendations? 4G is sufficient, the headunit doesn't support 5G.
Thanks!
gapboy
what is NVMOs? or are you referring to MVNO ?
Get a local prepaid card if you go Msia often.. i.e hotlink? i have that too ..
Can consider Maxx, Eight or ZYM plans comes with Msia roam
cj2502
LOL yes bro indeed i meant MVNO. Paiseh! Not too familiar with the terms.
I use Yoodo on my main phone, but for my car android, would prefer something local with roaming. The unit can only take one sim card hence would be troublesome if i buy a local prepaid card and gotta keep switching.
cj2502
get eight, cheap and good. $8/mth, you get 10GB apac data
Ya, considering the switch to Eight. But wondering about the connectivity in Msia hence wondering if anyone who has used it can share their experience?
Jurong640
you may see people's experiences roaming with eight in the eight thread. I've roamed with eight and simba in Johor before.
for eight, i roamed at Kluang Johor. Not bad quite fast, but when i was on the way back to Singapore, on the small road that connects to NSH, i got E on my network, pretty slow. I assume and think that it's because of that area quite ulu, so having E is pretty normal. I think the road ia Jalan Koti-tinggi - Kluang
cj2502
Ya i searched a bit in the thread but quite hard to finish looking through 400+ pages. In your opinion, if you had to choose between Eight and Simba in JB, which would be your choice?
For Simba i frequently get 0 signal, not even E. Not too sure if its an inherent problem of the Android or just that Simba is really bad. Works 30% of the time, but when it works its really smooth though.
Jurong640
if you are putting it for your car android head unit, i think you take eight better. In JB, my data connection was not bad, able to get 5G, though understand your's only support 4G.
Moreover, in Singapore, it has more data at 228GB. Do you need talk time for your car android head unit, otherwise you can consider their data only plan, also cost $8, without talktime.
gapboy
using Simba on mobile is fine in Jb driving there are bound to be blind spots when driving especially some highways
cj2502
Indeed bro. I am leaning towards Eight as well. I figured nothing to lose anyway, if it proves to be worse than Simba then i will just return to Simba. No termination fees anyway.
Yup i have no need for talktime. Eight's dataplan is stupid though. Same cost as the normal plans, and they simply take away call time/sms etc. Not sure what's the point. I might as well sign up for the normal plan just in case one day i need the sim card for other uses :D
cj2502
For some reason mine is especially worse bro. Just driving around in JB city... always no connection. I like to use Waze on my headunit hence its quite irritating when you want to navigate around and there's no connection :cry:
tohchr
I am using SIMBA with a 4G/5G standalone router in the car. HU is using wifi and never experience any issue.
Wherever I go in MY, I am always connected and my HU is an android base, watching youtube and navigating using waze..
gapboy
But i know that sometimes Manual selection of roaming partner to Cellcom is better than auto selection, give it a try.
cj2502
Ahh ok, maybe i should consider the option of using standalone router instead of the sim card directly in the headunit. I tried it out previously on another car but felt the speeds were a little slow compared to inserting the sim card directly into the unit but that might have been the router being an old model.
