Recommendations for USB hub?
ryanseah
Hi all, been searching high and low but seems like not many such products these days.
Looking for a USB hub with a long cable to connect from my PC to my desk so that I don't have to keep reaching behind to plug in USB items. Preferably has USB-C and USB-A 3.0 ports.
Most hubs these days seem to have very short cables and are meant for laptops.
Thanks in advance!
keenklee
I used j5Create (USB Type-A to USB Micro B - All USB Type A ) - connected 2x dual bay HDD docks. No issues with TBs transfer.
I also have U-Green Type C connected to Thunderbolt 4 ( all USB Type A ports ). Issue when transfer large numbers of files. Not sure if USB hub or port issue.
Kennedy
Shopee Ugreen or Vention ( cheaper ). usb extension cable if needed.
contacted
I use a Ugreen USB hub that has a KVM functionality too. So I share my keyboard, mouse, speakers etc with my desktop and laptop.
Alphas
Yes, longer cable will have larger voltage drop. Or get a powered hub.
wlalala
actually i looking for one also
need one to plug into rear usb ports then stick the hub on the side of the case so I can use it in front
so i guess the cable around 1m long will do
I want mix of normal usb and usb c though, any similar to what @kandinsky linked?
