Red Wing shoe Thread
StanII
I don't really know much about RW shoes, but if I'm not wrong, the numbers just means the colour, so both the 875 and the 1907 are the same style, but different colour and material (i think?).
The 1907, when you literally scratch it, the mark will stay there, and it'll be quite obvious, but i think you should be about to just manually wipe it off, whereas the 875 don't have such thing
But if i were to choose between those 2, I would go for the 1907, because if you look around the streets now, you'll see more 875s around, it's quite common now. The 1907 gives a more rugged and seasoned look :)
Just my two cents worth!
meaning to say 875's material is tougher than 1907's since you were syaing about the mark being left behind.
but usually the 875 after a while, the leather will darken in colour due to the mink oil in most bro's cases i've seen.
bjornng
yeap! anw i'm looking at the Red Wing Boots 9013D Classic Round Chestnut Featherstone and the Red Wing Boots 8113D Hawthorne Muleskinner.. thinking which to get. just by looking at both i can get high
daggerden
beside Suntec, any shops at Orchard selling RW ?
Beside suntec RW store, well i think there is The denim store @ mandrain gallery. Leftfoot @ cine/fep/ cathay. Woodland310@heeren also stock them. Orchard Central down abit, across the road also have one shoe shop also sells them.
Out of town area, there is queensway shopping centre. JP have one. Think there should be more, but ya, here is more than enough.
Well, i suggest u going to suntec cause they have got proper measuring foot tool so they can give you advises on your size. My 2cents, Cheers!:)
strongcow
Hi,
I'm a new member. I would like to share some of my collections, as I am a Red Wing fans too.. :)
PS : From top - bottom>> (FIRST PICS)
8130
877 - Vintage 1990 version
8165 - Vintage old logo ( 90's as well ?? )
875
4429 - Vintage, appx 1960-1974
9016 - Cedar Color
4579 - J.CREW, GT-Beckman Rugged Boots
1905
Been collected for almost 3 years already.
First time I only collected vintage ones, but due to the sizes (too big/too tight), I sold some of them. So only left those.
I wear 9 - 9,5 US size.. :)
strongcow
Hi,
8130
875
9016 - Cedar Color
1905
Studded
Hi all,
I'm a new member, I have trouble posting images/photos.
It appeared this message>>
The following errors occurred with your submission:
1. You do not have sufficient post count to post images/links. Please remove the images/links from your message, then you will be able to submit your post.
So, how much do I have to post, so that I have sufficient counted posts?
Anyone could help me? Thanks..
Insufficient post count to post any pictures :( go PCW more
stan91
Hi guys, just bought my first pair of redwings moc toe 8131 from hk, is that anyway that i can clean it? Cause its kinda dirty like alot dirt and dust. ahaha
d3n
Use a clean cloth and damp the cloth with warm water.
abuddlah
Hi everyone, just bought my 875 from Fender Sports from Penisula cause RW shop in Suntec dont have my size and they recommend me to go to Penisula to buy it. But pardon me, can someone tell me how to check if my 875 is authentic?
mlstic
can expert provides a tips on matching it with a nudie jeans? E.g.
1. Which are the cuttings not suitable for 1907 RW?
2. Will a Tight Long John nudie match with 1907 RW?
CallmeZen
TLJ will definitely looks weird with the super skinny cutting .
if you're looking for a slightly skinny cut , go for thinn fin , will look awesome .
