Red Wing shoe Thread
Dj-Jax
so do the store in singapore carry the japanese model?
just found out the one i beoing is a japanese design.
yea i got this from the original red wing store in suntec. 2906 is a jap design. you are right! :D
cowculator
Hi, may I know how long can the soles of a pair of red wing boots last?
Thanks
will last longer than you.
I like my red wing just fine but let's put things in perspective. There's no way the soles are going to last a lifetime unless you are saying that the guy can't live longer than 5 years.
Depending on frequency of use and your gait, they will probably need to be re-soled once every 2-4 years. The uppers will last a long time if properly treated.
Also, they are just boots, there is no need to treat them like some kind of atas thing to be worshipped. If they don't fit well or feel comfortable after a period of break in, it means it is a poor investment no matter how costly it is or how good the reviews are.
cutiepie23
i went to suntec liao
the sales girl measured my foot liao
it is 10.5 n E
but when i try 8138, she let me try 11 D and 10.5 EE
11 D, i felt that there is a lot of room in front of my toe...
10.5 EE, too big till my foot can move left n right...
so which size should i get?
I am planning to get 405 soon, i need some advise on the sizing... as i will be ordering from the states then sent to singapore...
Should i get 10.5 D?
Singapore do not have 10.5 D...
Bloodbro32
it is 10.5 n E
get singapore site to order 10.5 D for you.
If you order from us, got problem and need to ship it back. no worth to try. i did that before. :(
cutiepie23
i getting the distributor to order for me... :X
but he told me need to take 3 mths... lan lan wait lo... if wrong then have to wait another 3 mths le.... will suck thumb... so better play safe 1st
Nixon77
redwing sizing
Hi, does anybody know what size of Redwing matches US10 for Nike dunk?
I saw a 8 1/2 D pair 866 on ebay US.
Thought of bidding for it but not sure if it fits.
Can anyone out there give me some advice?
screws
dnt knw havent really break mine bt i feel they fit true 2 sz. im size 8 1/2 D. f dunks fit snug, it wil b too small 4 u.
cutiepie23
i had just went to left foot to try on another size... 10 EE.
it fit nicely...
but the boots looks very season liao...
Should I take 10EE or 10.5D?
foot measurement is 10.5E
Melicious
yea. have queries bout the size. i see the sizing got 8EE, 8D, 8D(M).
might want to order online.
cutiepie23
D is normal side of the side
EE is wide at the side lo
there is only E too....
go suntec n measure 1st la
heehee
then both of us can think which size to get
lol
:X
stonesix
it fit nicely...
take what fit you the most....what do you mean the "boots looks very season lioa"?
isn't it new?
stonesix
about the what size fit you, the best way to find out is to try it your self, don't take risk of buying "agar-agar" size.
And also, if you really need to take the risk, take the bigger one, its easier to fix. If you take one that smaller size than your feet, then sorry...no solution.
cutiepie23
isn't it new?
i think too much pple try liao
ok... 1 big big question to all red wing user
went you get ur red wing boots, the side aka width of your foot feel a bit tight or still got a bit of room (2 to 5mm space)?
Do you all get a very fitting 1 (a bit tight) then break in? or get just nice or got a bit of allowance on the side, then don need to break in?
what i heard from red wing youtube is it will try to form the shape of ur foot after the break in... so u all get tight or just nice with min allowance?
screws
4 those guys who r looking 2 get red wing locally, get them quick while stocks r still made in usa. went 2 marina square shop today & the sales lady mentioned next shipments gonna b mic. :(
cowculator
they have been making shoes in china for a long time already. Some models are still being made in USA as far as i know, cos there is demand for them. This hasn't changed.
If the shop says they are taking the made in china ones in, either a sales tactics to make you buy now or they just want to have a lower price range for people with lower budget.
Teaken
Get the pair of red wing that fits well on you with sock, no such thing of buying reduced size so that the shoes will break into u. When the shoes seasoned, it will fit nicely on u.
For those went through NS, it is the same concept on your army boot, do u upsize to charge up the hill better? ;) u decide..
As for width sizes, red wing(SG) brought in D size only, I supposed due to skinny jean skinny boot? :s13:
U can try to order and sit tight if D don't fit well on u, gd shoes are worth waiting. Rem, don't buy if tight on side, your leg will suffered in long run, it should have min gap at side with sock worn.
Nowadays, hard to find size E & EE, managed to find mine by chance, I'm wearing size 9E.
cutiepie23
i was so damn confused..............
then lastly i saw the discount on shoebuy.com has been removed!!!! WTF!!!
Looks like shoebuy seldom give 20% discount... so i faster wack...
I just got myself 10 EE.
I was like thinking... i seldom wear jeans during weekend... and i getting company to get me another red wing which is 405... but it's china made... plus it has safety feature... so can buy... 8138 do not have safety feature... so lan lan... i need to buy myself...
then i think n think... WTF... shoebuy 20% is removed... ahhhhhhh
then faster wack before i really regret...
did i make a stupid move?
* note: I seldom wear jean on the weekend... normally i wear bem n slipper 1...
even go orchard also the same...
maybe occasion then will wear jeans, which i thought this will be a good time to wear the boots... also i can wear to work, but i am getting another red wing for work only...
